Wes, according to the service manual, the part number for your computers power supply is 661-5299. that is compatible with the following:"
iMac 21.5" 2.5GHz Core i5 (A1311) - Mid 2011
iMac 21.5" 2.7GHz Core i5 (A1311) - Mid 2011
iMac 21.5" 2.8GHz Core i7 (A1311) - Mid 2011
iMac 21.5" 3.06GHz Core 2 Duo (A1311) - Late 2009
iMac 21.5" 3.06GHz Core i3 (A1311) - Mid 2010
iMac 21.5" 3.1GHz Core i3 (A1311) - Mid 2011
iMac 21.5" 3.2GHz Core i3 (A1311) - Mid 2010
iMac 21.5" 3.33GHz Core 2 Duo (A1311) - Late 2009
iMac 21.5" 3.6GHz Core i5 (A1311) - Mid 2010
Hope this helps, good luck.
Votato
Annulla
Punteggio
3
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti
I would really like to know. I don't want to order a $80+ part if it won't work. Any suggestions?
da Wes
Contact iFixit directly this is the volunteer DIY help forum. If the part numbers match, or if iFixit lists the part as being compatible you'll be ok.
da originalmachead
