Salta al contenuto principale
The Time Capsule Model A1302 is the second generation of Apple's wireless router and networked storage device released in March 2009. Most information from these repair and disassembly guides also applies to the original Model A1254.
Request if a breakdown manual available
Hi Guys,
I have an Apple 2TB time machine in which the reset button on the back in damaged and I am unable to reset it so that it can rejoin my home network. I want to remove the HDD and install it another enclosure and use as a backup external HDD. Apple do not repair these, as you probably know.
If there is no breakdown manual and/or video can you suggest the safest way to break open the TM and retrieve the HDD from it?
Also, can you suggest a suitable enclosure that I could use to house the guts of the TM?
Many thanks for your help.
Cheers
Roger
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'm assuming your 2TB Time Capsule is the shorter, older, model.
This iFixit guide should walk you through removing the hard drive. The gist of the repair is you will remove the rubber bottom using a heatgun or hairdryer along with a paint scraper to work through the adhesive. Once the rubber bottom is removed you can unscrew the metal bottom cover and access the hard drive. Honestly, the rubber bottom is the biggest hurdle in this repair, once it's removed the hard drive is then very easy to remove as well.
This video shows the process as well.
Once the hard drive is removed you can install it into just about any 3.5" SATA hard drive enclosure. The guts of the Time Capsule would be a bit harder to source an enclosure for. If it were me I would try to remove just enough to perform the reset, then reinstall everything into the original enclosure. The rubber bottom could be placed back on without the adhesive which would make future repair much quicker if necessary. If the reset button is hard to reach then you may be able to widen it's access hole once the Time Capsule is all apart.
Hopefully that helps!
Punteggio 1
1 Commento:
Many thanks for your help. The video was very helpful.
da
Aggiungi la tua risposta
rogera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,661
