Salta al contenuto principale
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
602 Domande Visualizza tutte
Installed HD in iMac - "Select a destination" HD missing?
Hey ifixit
Bought your 2 TB HD for my iMac (EMC 2133) because original HD had crashed. Followed your guide for replacing HD without problems.
Now starting the iMac from disk I come to the "Select a Destination" window but no HD shows up in the list. So I'm stuch here.
Tried the disk utility and the HD does show, but I can't verify or repair it. Seems that nothing can be done with it. No participation showed.
Also tried a trick I read in another threat on apple.com to go into Terminal and type "df -k" a couple of times. No luck.
What do I do?
Questa è una buona domanda?
Punteggio 0
Commenti:
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
Kit di riparazione batterie iPhone
Solo $29.99
Buy Now
Solo $29.99
Buy Now
2 Risposte
Risposta Più Utile
Sounds like the connections need to be double checked. Go ahead and email support [at] ifixit [dot] com so that we can further assist you. Thanks!
Punteggio 1
Sounds like the drive hasn't been partitioned correctly.
Ensure that the following are correct,
In disk utility Click the Volume not the drive
Click the "Parition" tab
Partition Layout = "1 partition"
Click Options…
Click GUID Partition Table
Click OK
Name the partition "Macintosh HD" or anything you want
Format should be "Mac OS Extended (Journaled)
Click OK
The HDD will now partition and will be available in the "Select a Destination" window.
Let me know how it goes, as always if you need any more help just ask.
Cheers
Brendan Mills
Punteggio 1
Aggiungi la tua risposta
Timm Willum Larsen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 220
