Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Flickering backlight... how do I fix it?
I just finished assembling a new front display (LCD and digitizer) on my Verizon iPhone 4 because I had a cracked screen. Everything works great, except the backlight on the screen seems to be flickering...it's very subtle, but soon it will start to drive me crazy Does anyone know why this might be, and how I could go back and fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
try turning off the auto brightness.
if that didn't work you have no other option than replacing it. it a common fault on these copy's
Punteggio 1
1 Commento:
Yep: my aftermarket replica screen had flickering/pulsing brightness. Over one month of use did not magically break it in or burn it in. Auto-Brightness has nothing to do with it, in my instance. I replaced this copy with a used Apple original, and problem is gone. It was just a lousy copy.
da
Aggiungi la tua risposta
Katie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,099
