Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
iPhone 4 boots when plugged in but not when unplugged
One time my i was playing on my iphone 4 and it went black, it couldn't boot, I sent it to replace battery but when i got it, the phone said 1%, i charge it, it goes to 100%, disconnect it and it goes black and i plug it in and it says 1% again. The guy said it might be the dock connecter, please help, no phone is stressing me out, thank you.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
ericksol96, the part I find very interesting is, that the person that replaced your battery, did not seem to have checked the charge function at all. If the battery is definitely new, triple check with the person that replaced it, then the next step would be the dock connector. Here is the guide for it. Again, double check with the person that you send the phone to, to find out exactly what they did. Hope this helps, good luck.
Punteggio 1
There is no doubt that the battery is replaced incorrectly.
Try to correct for someone else
Punteggio 0
Aggiungi la tua risposta
ericksol96 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 139
