Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Random freezing and display fault
HI,
Recently I'm facing issue with my white MacBook (Early 2008) which is randomly freezing and a message shows that i have to turn off the machine. Sometimes during this freeze the display shows some sticky line or numbers or characters flickering.
Best Regards
Aryan
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Often when I see a system freeze up it's caked up with dust and likely needs to have the thermo paste re-applied. I would start with cleaning if the problem is still persists you may have to reformat the HD and re-install your OS & files (your HD maybe having problems).
Are you up to taking your system apart? Do you have the needed tools, ESD mat & wrist strap?
If you do follow this guide Upper case removal. Make sure to fully scrub down the logic board, heat sink fin from the back and fan with a soft brush. Using can'ed air blow out the junk. Follow proper ESD practices!
If the system is not that dirty you should consider pulling the heat sink off so you can apply fresh thermo paste onto the CPU & GPU to get better heat transfer as the old paste is most likely not doing a very good job any more (causing the fan to run hard). Follow this guide to Step 26 (you don't need to go all the way here) Logic board removal
Immagine MacBook Core 2 Duo Case Superiore
Guida
Sostituzione Case Superiore nel MacBook Core 2 Duo
Difficoltà:
Moderato
45 minutes - 2 hours
Immagine MacBook Core 2 Duo Logic Board
Guida
MacBook Core 2 Duo Logic Board Replacement
Difficoltà:
Difficile
2 - 3 hours
Punteggio 2
3 Commenti:
hi,
but this is not related to over heating or HD, its happening usually only when im moving it....
da
Your system was not designed to be moved about running, lid open (excluding sleep mode).
da
I would still do a good cleaning first as your system likely needs it do to it's age.
da
Aggiungi la tua risposta
aryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 142
