Salta al contenuto principale
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
20 Domande Visualizza tutte
Blackberry dropped into a bucket and just found
My Blackberry fell in a bucket of water several days ago. We removed the battery. There is water under screen.
There is a white part which we also removed. We have done noting else.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
jacques W, now would be a good time to do something:-) before corrosion gets worse. Keep the battery out of your phone and do not try to turn it on.You do want to totally disassemble your phone. Use these guides to do so. Once it is disassembled, clean every single part, connector and cables ends with +90% isopropyl alcohol. Check this guide to see how it is done. It was written for a iPhone 3G but all the points are still valid for your phone as well. Once you have it properly cleaned, replace the battery check for obvious damage and reassemble your phone. Check for any problems with your phone and address those as they show up. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
jacques W sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 302
