Salta al contenuto principale
Domanda Chiusa
Why does LCD screen have a vertical 1 1/4" solid white line?
Having read about lcd issues from other posted questions it appears that my issue is a bit different. I woke my computer from its nap and there was a wide solid white vertical bar about 1 1/4" wide. Just previously there where no vertical lines at all. When i change the resolution the white bar remains. When i start the computer the affected bar area is made up of a lot of vertical colored lines and by the time i am logged in it is a solid white bar. Is this a failing LCD screen or something else?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Chances are 99.9% it's a bad screen. Screen issues that affect only part of the screen tend to be a flaw with the screen itself.
Punteggio 1
1 Commento:
Thanks for your quick response! i appreciate it…
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 740
