Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 e 3,2 GHz o Core i5 da 3,6 GHz
342 Domande Visualizza tutte
Domanda Chiusa
Can upgrade an ATI 5670HD to another better?
I Have a 21.5 IMac mid 2010 with the ATI 5670HD 512MB and Intel Core i3.
Can i upgrade this video card to another better? If it's yes, what video card do you recommend?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
See this previous Question.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
3 Commenti:
So what Graphics Card do you recommend? Thanks for the answer.
da
What do you intend to do that needs a "better" graphics card? What does that require? Get the one that meets or exceeds that need (incase the requirement increases).
da
You are also limited by the displays abilities as well here. If your system can be upgraded think about getting a new board with more memory if you are dealing with high motion video gaming otherwise you should think about getting a new system like a Mac Pro which has a PCI bus so you can customize things.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 468
