Salta al contenuto principale
Repair guides and support for many cameras in the Coolpix line by Nikon.
703 Domande Visualizza tutte
Domanda Chiusa
SD card is not reading on Nikon CoolPix S51
I have a Nikon CoolPix S51 and I try to replace the SD card but doesnt read it. Is the SD slot card reader not working properly ??? How can I fix it ??
Questa è una buona domanda?
Punteggio 0
1 Commento
Did you replace the SD card by a equivalent model ?
What is the memory size of the first and the second card ?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The following is a list of approved memory cards for the Coolpix S51 digital still camera. These cards have been tested and approved for use with the Coolpix S51.
The S51 uses SD (Secure Digital) memory.
SanDisk
  • 128 M B, 256MB, 512MB, 1GB, 2GB 1, 4GB 1,2
  • High Speed , 10MB/s cards: 512MB, 1GB, 2GB 1
  • High Speed , 20MB/s cards: 1GB, 2GB 1
Toshiba
  • 128MB, 256MB, 512MB, 1 GB, 2GB 1, 4GB 1,2
  • High Speed, 10 MB/s cards: 128MB, 256MB, 512MB, 1GB
Panasonic
  • 128MB, 256MB, 512MB, 1GB, 2GB 1, 4GB 1,2
  • High Speed 10 MB/s cards: 256MB
  • High Speed 20 MB/s cards: 512MB, 1GB, 2GB 1
1 If the memory card will be used with a card reader or similar device, the device must support memory card specifications. If the device does not support memory card specifications, insert the memory card into the camera and connect the camera to a computer via the supplied USB cable totransfer images.
2 SDHC Compliant
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Hope it will help you....
If this answer was helpful please remember to mark it accepted.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,515
