Salta al contenuto principale
Informazioni e guide di riparazione per i modelli MacBook Pro con display da 13".
9744 Domande Visualizza tutte
Preventing further corrosion on coffee spill
HI,
I had a shop professionally clean my macbook of coffee spills, and they said there is still chance for corrosion since they couldn't get under every little part. I was just wondering if there was anything I could do to prolong my macbook corroding, or does it have a set lifespan?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I hope you didn't pay too much for that cleaning. . . you've done as much as you can at this point. Use the laptop until it fails there's no way to estimate when that might be (the best time to prevent corrosion is before you spill) .
If this answer was helpful please remember to mark it accepted.''
Punteggio 1
2 Commenti:
So not using it would not help at all?
da
No, corrosion takes place through time and oxidation - using it might actually slow the corrosion as the inside gets hot through use, which could lower humidity.
da
Aggiungi la tua risposta
cleevee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 542
