Salta al contenuto principale
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Do I have to change the gasket?
I have a cracked glass on my iPad 2 wi-fi and I am going to change it. I have replaced this on another device before so I am familiar to the steps on how to do it.
My iPad got a pretty bad dent in the aluminum which I will have to modify.
I read this post http://blog.missionrepair.com/2011/10/11...
and they recommend to change the gasket to keep the dust from coming into the display.
Would you say that is necessary judging from my pictures?
http://i47.tinypic.com/vxc678.jpg
http://i46.tinypic.com/2h7kkmt.jpg
http://i47.tinypic.com/34ytyz4.jpg
http://i47.tinypic.com/2zp5rup.jpg
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No you will not have to change the gasket, it looks in good condition. Getting the aluminium body back in shape will be a difficult job.
Let us know how it went.
Punteggio 0
1 Commento:
Any tips on fixing the dented aluminum?
da
This is not the gasket, just a plastic bezel. Pry the glass carefully, the bezel should be reusable.
The original LCD gaskets are 2 L-shaped foam tapes. They are inevitably torn during disassembly and very hard to find on the market.
Notice the detail of the original ones. The ends match perfectly and there is a curve for the home button.
Punteggio 0
Aggiungi la tua risposta
robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 719
