My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Questa è una buona domanda?
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 394
