Salta al contenuto principale
Domanda Chiusa
My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Punteggio 0
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 394
