Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Are the displays of the C2D and CD MacBooks compatible?
Hi there,
it's basically the same issue I have with my other question: I have two MacBooks, one black, one white - one being a Core Duo, the other a Core 2 Duo.
I want to switch parts but at least the display. Are the displays compatible with each other? I have seen there are two / three antannae cables ... what do I have to do in order to get things working?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
OK, I figured it out myself. The two displays are compatible, to a point.
The C2D was a Merom and had an AirPort card with three connectors. I tore both the 'Books apart and switched the display and the AirPort cards et voilá.
After all it worked out fine! :)
Punteggio 2
2 Commenti:
Good deal--if you would please accept your answer now to clear the problem. Thanks
da
Aggiungi la tua risposta
Kevin Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 602
