Salta al contenuto principale
"Kernel Panic" message on screen
I have a used iBook G4. It's been working great for 2 months. One morning I booted it up and this screen came up with a message that states that I must restart the computer now. So, I turn the power button off and restart the computer. The screen is still frozen. Later another message appears under this message. After further investigation, I learn that this is a "Kernel Panic".
According to Wikipeida, a "kernel panic is an action taken by an operating system upon detecting an internal fatal error from which it cannot safely recover."
What can I do to fix this? I've tried holding down the shift key just before the grey screen comes up upon reboot, but it didn't work. The screen is still frozen.
I haven't added any software or removed any. I haven't downloaded any software. I was on Safari prior to it crashing.
Are there discs available to repair a "kernel panic"? Should I take out the OS and replace it? Should I add more RAM? Or, should I take it in and get it looked at by a professional? Would it cost a lot of money? Is it even worth taking it in and repaired, or should I buy another mac?
I hope somebody out there can help me 'cause this is really bothering me. I've been without my Mac now for 2 weeks. Using my husbands IBM PC and really miss my Mac. Thanks. Rose
Questa è una buona domanda?
Punteggio 2
5 Commenti
This interesting I also run into a sever kernel panic and could not even start up anymore
(see post with kernlepanic tag). Before that I had a lot of trouble with bluetooth (showing the grey icon, saying bleutooth not available). Before the very sever kernelpanic (i had many others before, but could start up finaly of these other cases), the machine also said that airportcard was not configurated! When I tried to get to the char, it was not even listed! Does all this make any sense? Please, help needed.
da
Open up the iBook and remove the airport card then try to boot after just connecting the top case power switch connector. If the iBook works normally then the Airport socket if probably faulty.
da
I add this in the hope that anyone with this problem will try this fix before going to the lengths and expense as suggested. This is a common problem with iBooks with inbuilt Airport Cards. Once you have established that you can isolate the problem to the Airport Card by turning it off and the Kernel Panics stop go to:-
http://hints.macworld.com/article.php?st... follow the instructions and then simply buy a wireless dongle on ebay for under $10.
da
I've got an old iBook G4, 14"/1.42 GHz/Tiger
It has the kernel panic problem when AirPort is on. When setting AirPort off, the computer works for hours and hours.
For my surprise, setting Bluetooth on allows me to work in internet without problems (via iPhone). I have understood that both Bluetooth and AirPort are taken care by the same internal card - am I right?
Apparently my problem is in Card and not in the connection/ motherboard connector?
da
It doesn't have to be the card. The system bus still has to communicate through different pins of the card for Wifi and Bluetooth, and it could be that it's the WiFi only pins that go bad. Looking at mine, some have a green tinge, and I suspect that this is corrosion due to a combination of heat, current drain, and cool off condensation. It spells the end of an otherwise brilliant machine.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
The iBook G4 12" 1.33GHz is known for having a problem with the airport/bluethoot socket on the logic board causing kernel panics events. Try to desactivate Airport and bluethoot and check if the problem persists. If the iBook works without problem after the desactivation then your airport socket is faulty. You may try to reseat the airport card but often the problem will reappear. The only solution is to remove the airport/bluethoot card from the logic board and use a USB wireless dongle as a substitute for the airport card or to replace the logic board.
Punteggio 6
3 Commenti:
+1! This just turned out to be the answer on a problematic 1.33GHZ...at a loss for other things to try, I booted in safe mode and was surprised to realize it worked fine, and of course then I noticed that the Airport wasn't active in safe mode, which made me think, hey, maybe that's the problem? And your post verifies that that's most likely it. Thanks!
da
+ Ralph
da
agreed +
da
This is the logic board you'd need if it doesn't turn out to be the Airport issue Lemerise mentioned (or if it is the Airport issue, and you still want to replace the board):
[prodotto collegato mancante o disabilitato: IF183-042]
Please note, it may be cheaper to buy a used board, or a whole new machine for that matter, on eBay.
Punteggio 2
This 99% of the time means a bad logic board, unless you're very proficient, have the time, and are willing to spend the money, it's not exactly worth it to replace the board. What you can do, however, is salvage your data by taking out the hard drive using this guide and putting it in an enclosure, from which you can transfer your data after replacing your computer.
Punteggio 1
Aggiungi la tua risposta
Rose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,492
