Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
No input/output Audio Devices
MacBook 13" Unibody (Model A1342) Mid 2010 , Mac OS X (10.6.8)
The sound suddenly stopped. On System Preferences, on Audio, it shows the sound as muted and doesn't allow me to unmute it. System Profiler shows Audio (Built-in): Intel High Definition Audio: Audio ID - 0, no input/output Audio Devices. I fixed the hard drive access permission , did the reset for both pram and smc several times and finally installed a clear copy of mac OS after deleting the HD, but unfortunately ended with no success. Do you think it is a hardware related problem? How do I fix this?
 Thank you in advance.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello Mary, Apparently Apple has a problem with the 10.6.8 update having to do with audio. I am including a link to a discussion on the subject. Hope this helps you.
http://support.apple.com/kb/HT4561
Including a link to the support page also.
http://support.apple.com/kb/index?page=s...
Punteggio 2
Thank you for your reply. I installed the update and restarted the computer but with no luck. The advanced hardware test i run shows no errors!!!Do you have other suggestions? thanks
Punteggio 0
Aggiungi la tua risposta
Mary sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,984
