Salta al contenuto principale
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Solid Red Screen after digitizer replacment
After a digitizer replacement the LCD is solid red see photo. I tried another LCD same issue, so its clearly something on the board/connector but it was not like this before the repair.
Any help is appreciated.
https://www.dropbox.com/s/748sx9qb1gtp7o...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
It's some sort of loose cable. I've had the exact same thing happen to me after my ipad2 experienced a slight drop on the floor.
(You can still see things on the screen, but the red pattern is still always sort of there in the background, right?)
Anyways, I read about this happening to other people online (try googling it) and the solution suggested one place, was to punch the back of the iPad.
I turned it around, gave it a good solid couple of whacks, and it fixed the problem, works fine now.
Punteggio 0
You most likely picked up a defective LCD. You can always try a hard reset, if it doesn't change anything this is probably the issue.
Punteggio 0
1 Commento:
The LCD was fine before the glass replacement. I tried a known good LCD and the iPad had the same issue. I still would like to know what causes this
da
Ha! worked punching in the back
Punteggio 0
check the chips and component around he LCD connector,,,,,use magnifying classes
Punteggio 0
Aggiungi la tua risposta
Kyle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,646
