Salta al contenuto principale
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
Sound but no picture?...
Hi
I havent seen this one crop up in any threads so far. Sometimes my XBOX 360 starts up with only sound (no picture). One green light on console, no reds.
Changing cables doesnt make any difference. Checked for loose cable connections in back of TV and XBOX and all fine. I've used th etowel trick about 4 times now to 'reset' the XBOX and this works but it now a matter of days before the same problem arises, and I dont want to keep diong th etowel trick in case it makes matters worse.
Will re-doing the Heatsinks with Thermal compound be a worthwhile venture for this problem?
Thanks in advance for any useful advice...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Rob, this most certainly sound like an overheating issue. I suggest to not do the "towel trick" any more. The issue is that it will cause way more problems (trust me, been there:) I would at least try to get the RROD fix kit and install it, using this guide. Yes, thermal compound may help, but I think it will need a bit more work. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,139
