Salta al contenuto principale
L'APC RS 1000 è un gruppo di continuità in grado di erogare 600 Watt.
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
Questa è una buona domanda?
Punteggio 5
1 Commento
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
da
Aggiungi un commento
5 Risposte
Soluzione prescelta
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
Punteggio 2
Risposta più utile
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
Punteggio 4
3 Commenti:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
da
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
da
Green light not so always yellow light and 5 Second deep alarm
da
- Turn off the unit
Good Luck...
Punteggio 2
1 Commento:
Thank you but I replaced the old ups with a new one. Yours sincerely.
da
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
Punteggio 1
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
Punteggio 0
Aggiungi la tua risposta
Roberto sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 44
Tutti i Tempi: 39,494
