Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20012 Domande Visualizza tutte
Domanda Chiusa
Spilled a little wine on my MacBook Pro. Can't turn Wi-Fi on.
I accidentally splashed a little red wine on my MacBook Pro. Wiped it off the best I could and left it alone overnight.
Everything works fine except I can't turn on Wi-Fi. I went to network in systems preferences...followed assist....nothing. I can't get any networks at all. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Immediately remove all power including the battery from your unit. Then follow the ifixit liquid cleaning procedure. After that just use the power brick and check out your computer. If all is well add the battery and check again. If you are still having problems please get back to us. Good luck.
Electronics Water Damage
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 750
