No hot water in boiler, keeps flashing F5?
My furriol boiler keeps flashing F5, and am only getting hot water for a couple of seconds at a time, will i need to get a new boiler, or can this be fixed?
Visualizza:
Voti ApprovatiChiunque supera la reputazione 20 può contrassegnare commenti e post problematici.
Mostra i dettagli
Rep: 13
Postato:
Rep: 782,4k
Postato:
Lindsey, not sure what boiler you have, the only info I got is for a Ferroli boiler. Again, there are numerous of those. If you can a model number would be helpful. On the Ferroli Optimax the F5 error code is:
Fan problem
• Tachometer signal
interrupted, fan connection
• Fan damaged, debris in fan
Possible Solution
• Check the wiring and fan
• Check the fan, clean debris
Hope this helps you to get started. Good Luck.
Oops! Vorrei cambiare idea.
Espandi / Comprimi
Riuscito
Su
Fallito
Giù
Apri Aiuto
Pagina 1 di 1
