Salta al contenuto principale
iPad Air 3 Screen Replacement
Cosa ti serve
    1. iPad Air 3 Screen Replacement, Screen: passo 1, immagine 1 di 2 iPad Air 3 Screen Replacement, Screen: passo 1, immagine 2 di 2
      • Cracked near home button its important to not break home button flex cable
      • Apply heat to the screen! Do NOT SKIP THIS STEP
      • Make sure to turn it off if you can to prevent breaking the backlight filter
      Chiedi a FixBot
      Aggiungi Commento
      • Pry with splicer around the edges
      • Display cables are on the bottom of screen opening up like an upside-down note pad
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Air 3 Screen Replacement: passo 3, immagine 1 di 1
      • Lift from the top like so
      • Display Cables
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Air 3 Screen Replacement: passo 4, immagine 1 di 3 iPad Air 3 Screen Replacement: passo 4, immagine 2 di 3 iPad Air 3 Screen Replacement: passo 4, immagine 3 di 3
      • Set screen up a little bit to get to power connection
      • Power connection has PH000 screw holding it together
      • Slide a card under connection
      • Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Air 3 Screen Replacement: passo 5, immagine 1 di 2 iPad Air 3 Screen Replacement: passo 5, immagine 2 di 2
      • Lift display back up to get to the display cables
      • Unscrew 2 PH000 Screws from display cable bracket
      • Use the flat end of plastic spudger to lift off connections
      • There is 4 flex cables that need disconnecting
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Air 3 Screen Replacement: passo 6, immagine 1 di 3 iPad Air 3 Screen Replacement: passo 6, immagine 2 di 3 iPad Air 3 Screen Replacement: passo 6, immagine 3 di 3
      • Whoohoo we got it off now clean the edges for any broken glass
      • Keep track of rubbers covering proximity light sensor on the top
      • Light covers place on top of proxmity sensors
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Air 3 Screen Replacement: passo 7, immagine 1 di 3 iPad Air 3 Screen Replacement: passo 7, immagine 2 di 3 iPad Air 3 Screen Replacement: passo 7, immagine 3 di 3
      • APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
      • If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
      • Take of home button flex cover
      • Use flat end of spudger to pry up home button flex connector
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Air 3 Screen Replacement: passo 8, immagine 1 di 3 iPad Air 3 Screen Replacement: passo 8, immagine 2 di 3 iPad Air 3 Screen Replacement: passo 8, immagine 3 di 3
      • Reapply heat if you spent to much time getting flex unhooked
      • Pry with splicer under the home button bracket car
      • Clean glass around gasket
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Air 3 Screen Replacement: passo 9, immagine 1 di 2 iPad Air 3 Screen Replacement: passo 9, immagine 2 di 2
      • Install home button on new screen I recommend using liquid adhesive for this!
      • Push the home button a couple of times to make sure it stills on and make sure it is clicking!
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad Air 3 Screen Replacement: passo 10, immagine 1 di 2 iPad Air 3 Screen Replacement: passo 10, immagine 2 di 2
      • Connect all 4 Flex cables to the logic board!
      • Now at the bottom of the new screen screw in the battery connection to test the new screen!
      Chiedi a FixBot
      Aggiungi Commento
    10. iPad Air 3 Screen Replacement: passo 11, immagine 1 di 1
      • Test screen drawing on the notes make sure it works!
      • Adhere new screen with preinstalled adhesive and clap it!
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 56
Ultimi 30 giorni: 195
Tutti i Tempi: 5,049
