Introduzione
This guide shows how to remove and replace the lithium-ion battery for the Toshiba L55 laptop. If your battery is swollen, take appropriate precautions.
Cosa ti serve
Flip the laptop over so that the back cover is facing up.
Unscrew the captive Phillips screw securing the RAM cover.
Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
Disconnect the cable.
Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
Remove the two 6.8 mm long Phillips screws securing the battery.
Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
