Salta al contenuto principale
R36S Joysticks Replacement
Cosa ti serve
    • To replace a R36S Joysticks you need to follow the teardown guide and for the joysticks you pull up the small black latch in pace holding the together.
    Chiedi a FixBot
    Aggiungi Commento
    • Then carefully remove the ribbon wire wit the rounded part of a screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
    • Now connect the ribbon of the new joystick after taking out the other . Remember to push the black latch down to lock it in place.
    Chiedi a FixBot
    Aggiungi Commento
    • Repeat for the other side and your done! To be really honest the r36s is probably the most easy thing to mod and change stuff out for it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Sonny Coglan
Membro da: 07/03/26
139 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 28
Ultimi 30 giorni: 74
Tutti i Tempi: 74
