Salta al contenuto principale
OnePlus 8 Pro Battery Replacement
Cosa ti serve
  1. OnePlus 8 Pro Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Heat up the back edge of the phone with the iOpener / any HotPack.
    • Start with a long edge as it is easier to open the back cover in the next step.
    • You may also use a hair dryer or heat gun to heat the adhesive.
    • Be careful not to overheat the phone - the screen and internal battery are susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  2. OnePlus 8 Pro Battery Replacement: passo 2, immagine 1 di 1
    • Insert the opening pick in the middle of the phone where you heated it. Slide it along the edge to cut through the adhesive.
    • This can be a bit tricky, don't use any sharp objects as you can damage the case. It's reccomended that you use a plastic wedge tool such as the one by iFixit, as it has a thicker ledge to prevent you from slicing too far in.
    • If it does not work, try heating the edge again.
    • Don't insert the opening pick too far. There are no flex cables in the way, but the wireless charging coil could be damaged.
    Chiedi a FixBot
    Aggiungi Commento
  3. OnePlus 8 Pro Battery Replacement: passo 3, immagine 1 di 2 OnePlus 8 Pro Battery Replacement: passo 3, immagine 2 di 2
    • Leave the opening picks once you managed to open one side.
    • Use heat on the next edge to open it.
    • Repeat steps 2 and 3 for all four edges.
    Chiedi a FixBot
    Aggiungi Commento
  4. OnePlus 8 Pro Battery Replacement: passo 4, immagine 1 di 1
    • Remove these screws (Phillips 00).
    • Remove this Phillips 00 screw. You can remove the white paper with tweezers or just push the screwdriver through the paper.
    Chiedi a FixBot
    Aggiungi Commento
  5. OnePlus 8 Pro Battery Replacement: passo 5, immagine 1 di 2 OnePlus 8 Pro Battery Replacement: passo 5, immagine 2 di 2
    • Carefully lift the two stickers which hold the wireless charging coil down.
    Chiedi a FixBot
    Aggiungi Commento
  6. OnePlus 8 Pro Battery Replacement: passo 6, immagine 1 di 1
    • Lift the charging coil.
    • Remove the two Phillips 00 screws below the coil.
    Chiedi a FixBot
    Aggiungi Commento
  7. OnePlus 8 Pro Battery Replacement: passo 7, immagine 1 di 1
    • Remove the top cover / coil assembly.
    Chiedi a FixBot
    Aggiungi Commento
  8. OnePlus 8 Pro Battery Replacement: passo 8, immagine 1 di 1
    • Disconnect the battery.
    Chiedi a FixBot
    Aggiungi Commento
  9. OnePlus 8 Pro Battery Replacement: passo 9, immagine 1 di 1
    • Pull the red pulling tab away from the battery.
    • Separate the red pulling tab from the black adhesive.
    • After separating, hold the black adhesive down and pull the red tab up vertically to remove the battery.
    • Make sure not to bend the battery too heavily.
    Chiedi a FixBot
    Aggiungi Commento
  10. OnePlus 8 Pro Battery Replacement: passo 10, immagine 1 di 2 OnePlus 8 Pro Battery Replacement: passo 10, immagine 2 di 2
    • Remove the red pulling tab from the old battery and stick it on the under side of the new battery.
    • This makes it easier to replace the battery again.
    • Insert the new battery.
    • Wrap the black adhesive strips on both sides around the battery to secure it.
    Chiedi a FixBot
    Aggiungi Commento
  11. OnePlus 8 Pro Battery Replacement: passo 11, immagine 1 di 1
    • Remove the old adhesive and replace it with new adhesive strips.
    • Reverse from step 8 to assemble the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Manuel Graf
Membro da: 01/21/20
220 Reputazione
Una guida realizzata
1Commento della guida
be carefull: the adhesives of the back cover are not only on the edge, but also on the 4 corners (see the back cover on photo of step 4). You should carefully cut these off from the short edges, BEFORE trying to lift the cover.
LeFils - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 61
Ultimi 30 giorni: 215
Tutti i Tempi: 2,998
