Salta al contenuto principale
Motorola Droid Turbo 2 Earpiece Speaker Replacement
Cosa ti serve
  1. Motorola Droid Turbo 2 Earpiece Speaker Replacement, Midframe: passo 1, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement, Midframe: passo 1, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement, Midframe: passo 1, immagine 3 di 3
    • Power off your phone before you begin working.
    • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • Remove the SIM card tray assembly from the phone.
  2. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 2, immagine 1 di 1
    • Heat an iOpener and apply it to the top edge of the phone for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 3, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 3, immagine 2 di 2
    • Angle an opening pick and firmly press so that it slips under the back cover.
    • Depending on the age of the phone, this can be difficult. Additional heating with the iOpener may help. You can pry carefully with a metal spudger to create a gap for the opening pick.
  4. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 4, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 4, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 4, immagine 3 di 3
    • Slide the opening pick along the top edge of the phone to break up the adhesive.
    • Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
  5. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 5, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 5, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 5, immagine 3 di 3
    • Repeat the iOpener heating and slicing procedures for the remaining three sides.
    • Make sure to cut into the deeper areas as the back cover is held on by a large adhesive surface.
  6. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 6, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 6, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 6, immagine 3 di 3
    • Once you have cut through the adhesive, slowly peel the back cover away from the frame.
    • Remove the back cover.
    • During reassembly, follow this rear cover adhesive guide to properly apply the pre-cut adhesive strip.
  7. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 7, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 7, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 7, immagine 3 di 3
    • Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
    • To reinstall the cover, align the cover and use your finger to push it forward into place.
  8. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 8, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 8, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 8, immagine 3 di 3
    • Use the point of a spudger to pry up and remove the coil connector rubber cover.
  9. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 9, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 9, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the flash connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 10, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 10, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
  11. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 11, immagine 1 di 1
    • Remove the following T3 screws securing the midframe:
    • Thirteen 3.1 mm black screws
    • Four 4.3 mm silver screws
    • Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel slightly loose. The bit should not feel like it's stuck in the screwhead.
  12. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 12, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 12, immagine 2 di 2
    • Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
  13. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 13, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 13, immagine 2 di 2
    • Remove the midframe from the phone.
    • You can tape over the side buttons to prevent them from falling out during your repair.
    • If the buttons fall out of the midframe, reinsert them in the orientation as shown before you reinstall the midframe.
  14. Motorola Droid Turbo 2 Earpiece Speaker Replacement, Earpiece Speaker: passo 14, immagine 1 di 2 Motorola Droid Turbo 2 Earpiece Speaker Replacement, Earpiece Speaker: passo 14, immagine 2 di 2
    • The earpiece speaker module is very delicate and prone to breaking. Be gentle when handling the module.
    • Insert a pointed end of a pair of tweezers into a corner as far down as possible.
    • Pry very slightly to help loosen the earpiece speaker module.
    • Repeat the process in the remaining corners.
  15. Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 15, immagine 1 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 15, immagine 2 di 3 Motorola Droid Turbo 2 Earpiece Speaker Replacement: passo 15, immagine 3 di 3
    • Continue to pry with the point of a pair of tweezers until the earpiece module feels loose.
    • Remove the earpiece module.
Conclusione
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
Altre 3 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
252.909 Reputazione
526 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.820 Guide realizzate
Un commento
I replaced my earpiece speaker but the volume is still extremely low. My headphones jack output is also very low when I plug it into and external speaker. Before this happened, This all started after I accidentally got some water on my phone but not enough to drench it. My speaker first sounded distorted when making a phone call and now the volume is so low that I can just barely hear it. Definitely too low to converse with someone. Is the fault in my motherboard? I've cleaned up all the obvious grounding points in my phone. Not sure what else I can check. Thinking about completely disassembling, replacing the ear speaker again doing a hard reset and if all those fail replace the phone. Any thoughts?
jeffrey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,418
