Salta al contenuto principale
Microsoft Surface Pro 7+ SSD Replacement
Cosa ti serve
  1. Microsoft Surface Pro 7+ SSD Replacement, Before you begin: passo 1, immagine 1 di 1
    • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
    Chiedi a FixBot
    Aggiungi Commento
  2. Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: passo 2, immagine 1 di 2 Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: passo 2, immagine 2 di 2
    • Open the kickstand to about 90 degrees.
    Chiedi a FixBot
    Aggiungi Commento
  3. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: passo 3, immagine 1 di 3 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: passo 3, immagine 2 di 3 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: passo 3, immagine 3 di 3
    • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
    • Alternatively, you can also use a small, straightened paper clip.
    • Remove the SSD door.
    Chiedi a FixBot
    Aggiungi Commento
  4. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: passo 4, immagine 1 di 2 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: passo 4, immagine 2 di 2
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
    • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
    Chiedi a FixBot
    Aggiungi Commento
  5. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: passo 5, immagine 1 di 2 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: passo 5, immagine 2 di 2
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use your fingers to pull the SSD out of its socket at a shallow angle.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Spencer Day
Membro da: 09/14/22
191.211 Reputazione
1.204 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 76
Ultimi 30 giorni: 250
Tutti i Tempi: 290
