Salta al contenuto principale
MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
Cosa ti serve
    1. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement, Lower Case: passo 1, immagine 1 di 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Chiedi a FixBot
      Aggiungi Commento
    2. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement: passo 2, immagine 1 di 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 19 persone hanno completato questa guida.
1Commento della guida
Walter, please, change this guide's difficulty from moderate to easy :D
It's really that simple.
P.S. You've really saved me. I opened it by myself but then noticed that screws were different size. Oh, I always remember iFixit and opened it cuz I was sure that I'll find smth here. Many thanks!
Jizo - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 29
Ultimi 30 giorni: 82
Tutti i Tempi: 32,347
