Salta al contenuto principale
MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement
Cosa ti serve
  1. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement, RAM Shield: passo 2, immagine 1 di 1
    • Remove the three identical Phillips screws from the memory door.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 3, immagine 1 di 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement, Upper Case: passo 4, immagine 1 di 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 5, immagine 1 di 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 6, immagine 1 di 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 7, immagine 1 di 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 8, immagine 1 di 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  9. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 9, immagine 1 di 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
    Chiedi a FixBot
    Aggiungi Commento
  10. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 10, immagine 1 di 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Chiedi a FixBot
    Aggiungi Commento
  11. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement, Left Fan: passo 11, immagine 1 di 1
    • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 12, immagine 1 di 1
    • Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
    Chiedi a FixBot
    Aggiungi Commento
  13. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 13, immagine 1 di 1
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
    Chiedi a FixBot
    Aggiungi Commento
  14. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 14, immagine 1 di 1
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
    Chiedi a FixBot
    Aggiungi Commento
  15. MacBook Pro 15" Core 2 Duo Model A1211 Left Fan Replacement: passo 15, immagine 1 di 1
    • Lift the left fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 66 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
6Commenti sulla guida
Hi Folks!
I'm a crotchety, 82 year-old geezer with big hands, and somehow or the other I managed to replace the left fan in my MacBook Pro 15" 1211 in about one hour! It was helpful to use a paper-mache egg carton to organize the little itsy-bitsy screw, because if you ever lost one you would never, ever find it again!
I had to use a big hammer occasionally to get things back together, but lo and behold my wife turned on her beloved machine and was very surprised to find that it works perfectly.
Many thanks for your great help and instructive manual!
Sincerely, Doc Botsford
mangeymooz - Rispondi Condividi
what a money saver and life saver. iFixit is awesome! Have to admit though you need to be fearless to open up your computer and take a chance. Be VERY careful with the connectors, and know how they are connected or they will break. The iSight cable pulls out to the left, but DONT pull on the wires. Use the spudger to wiggle out the metal tabs on the connector. Don't lift up on the connector. And the heat sink tape doesn't come off that easiy either. Once you pull the front of the fan upright so it's on it's edge, then use the spudger and go behind to pull the black tape off SLOWLY. And while you're reaching over those delicate prts, make sure you don't bang down on some resistor or other part. It's a thrill when you put it back together and you DON'T HEAR A THING! The fan is QUIET. Didn't realize how loud it was getting.
Bill - Rispondi Condividi
I finally got around to replacing both my fans. I had tried cleaning and putting drop of WD40 on the post of each one. They worked, but were noisy. Now I have replaced both fans and the computer is absolutely quiet(as far as I can tell) And cooler too. I went ahead and upgraded to 10.7(the highest OS it will take), so it is like I have a new computer. Thanks, ifixit
garyrclark - Rispondi Condividi
Looking for some HELP here, if anyone can help out.
Macbook Pro 15 2.33 had problem with defective left fan. Didn't turn on. I installed Macs Fan Control and tried to change fan speed, but it didn't show up in menu, so concluded it was broken.
I replaced it with a left fan listed as compatible with this model and with the next series, from 2007.
As soon as I booted up the computer with the replaced fan, it came on at full throttle and never slowed down. As soon as I press the power button, the left fan comes on.
So ended up with opposite problem! Left side is now very cool, but super noisy!
The install seemed to go okay, so I don't know what the problem might be. I reset SMC and PRAM, but no change.
Any ideas?
Simple Simon - Rispondi Condividi
Same here. Did you found a solution?
Anderson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 62
Tutti i Tempi: 65,923
