Salta al contenuto principale
MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement
Cosa ti serve
Panoramica Video
  1. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 2, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Battery Connection: passo 3, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Battery Connection: passo 3, immagine 2 di 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
  6. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  7. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  8. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement: passo 8, immagine 2 di 2
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
  9. MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: passo 9, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement, Hard Drive: passo 9, immagine 2 di 2
    • Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive.
    • Transfer the hard drive retaining posts to your new hard drive.
    • If desired, transfer the pull tab over to your new drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    • If you upgraded your EFI Firmware ROM you can also perform an internet recovery.
Conclusione
Altre 831 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
17.175 Guide realizzate
43 Commenti
You saved me $150 by helping me replace my hard drive on my own! Thank you!!! I know where to turn when my mac acts up now!!
Jennie - Replica
In case you need to install/reinstall your OS, the new MBPs no longer come with an install disc. To install your OS you will need to hold down CMD + R while booting up until it chimes. It will then walk you through the process.
Lynzi - Replica
After holding command + R during start up I ran into a problem using Time Machine trying to restore all the files in my system. Apparently the Samsung solid state SSD 859 EVO drive I put in first needs to be formatted before Time Machine can even recognize it! No error message appeared, but no destination disk could be located. Apparently that's what happens with an unformatted hard drive. The solution is to select Disk Utilities in the first window seen after pressing command +R. Then In the left sidebar I could see all the drives including the external hard drive with my Time Machine back up and also the Samsung solid state hard drive I installed. With the newly installed hard drive selected, use the default erase and re-formating options and click on ERASE (this will also format the erased drive). This operation was very quick. I then returned to Time Machine and voila, the hard drive was locatable as a destination disk.
Martin Kluger -
To the people that this still doesn’t work, try pressing cmd+alt+R, after connecting to WiFi go to Disk Utilities, format the new hard drive, and then you can proceed to restore or clean install iOS.
Felipe Mail-no-principal -
I needed to install the OS X in the new HD using a USB (manual in applesfera), then I was surprised when after do all this guide I see a message "Can't verified the copy...." I fixed reinstalling my old HD, and run the old OS, changed the date and time, I change again the HD, but (this is the important) don't pull off the battery connector. If you disconnect the battery, the system lost the date and time and yo can't install the OS X with and USB. I don't test the cmd + R option.
Agustin Jimenez Fernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 70
Ultimi 7 Giorni: 421
Ultimi 30 Giorni: 1,950
Tutti i Tempi: 1,050,898
