Salta al contenuto principale
MacBook Air 11" Late 2010 Solid-State Drive Replacement
Cosa ti serve
  1. MacBook Air 11" Late 2010 Solid-State Drive Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Late 2010 Solid-State Drive Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 Solid-State Drive Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Late 2010 Solid-State Drive Replacement, Battery: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 Solid-State Drive Replacement, Solid-State Drive: passo 4, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Late 2010 Solid-State Drive Replacement: passo 5, immagine 1 di 2 MacBook Air 11" Late 2010 Solid-State Drive Replacement: passo 5, immagine 2 di 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusione
Altre 36 persone hanno completato questa guida.
3 Commenti
is there any difference between SSD for macbook air and macbook pro...??
is that possible that we can just run macbook air only HDD..?
Rohit Lamba - Replica
Any chance of squeezing in an SSD any larger than 256 GB?
Just bought a late-2010 11" MBA off Amazon Marketplace, which was actually advertised as mid-2011. My plan was to upgrade it with a 1 TB SSD, which wouldn't have been a problem with the mid-2011 model. Seems this is not going to work with this one, right?
mariawinter - Replica
A bit of an oldie needs some help with upgrading his late 11" macbook air with a WD 500GB Blue SATA III 2.5" Internal SSD. Q 1 is it doable? Q2 Will I need an adapter "kit" of some kind or just be sure not to lose the screws in the process? Thanks in advance for any help. ted
Ted Buila - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 146
Tutti i Tempi: 109,344
