Salta al contenuto principale
Lenovo ThinkPad T560 Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
  2. Lenovo ThinkPad T560 Keyboard Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
  3. Lenovo ThinkPad T560 Keyboard Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T560 Keyboard Replacement: passo 3, immagine 2 di 2
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
  4. Lenovo ThinkPad T560 Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T560 Keyboard Replacement: passo 4, immagine 2 di 2
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
Conclusione
Clemson, Team 1-3, Hunter Spring 2022 Membro di Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 75
Tutti i Tempi: 1,590
