Salta al contenuto principale
Lenovo ThinkPad T480s USB Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s USB Card Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s USB Card Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s USB Card Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: passo 4, immagine 1 di 2 Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: passo 4, immagine 2 di 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s USB Card Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T480s USB Card Replacement: passo 5, immagine 2 di 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s USB Card Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 6, immagine 3 di 3
    • Lift the thermal fan assembly from the system and remove it.
  7. Lenovo ThinkPad T480s USB Card Replacement, USB Card: passo 7, immagine 1 di 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: passo 7, immagine 2 di 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: passo 7, immagine 3 di 3
    • Use a spudger to disconnect the cable from the USB card.
  8. Lenovo ThinkPad T480s USB Card Replacement: passo 8, immagine 1 di 2 Lenovo ThinkPad T480s USB Card Replacement: passo 8, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove two 3 mm screws from the USB card.
  9. Lenovo ThinkPad T480s USB Card Replacement: passo 9, immagine 1 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 9, immagine 2 di 3 Lenovo ThinkPad T480s USB Card Replacement: passo 9, immagine 3 di 3
    • With your fingers, lift the USB card from the system.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
Membro da: 03/11/19
23.706 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
138 Membri
17.676 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 586
