Salta al contenuto principale
Lenovo ThinkPad T480 Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: passo 1, immagine 1 di 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: passo 1, immagine 2 di 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: passo 3, immagine 2 di 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, immagine 3 di 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: passo 5, immagine 1 di 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: passo 5, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 7, immagine 1 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 7, immagine 2 di 3 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 7, immagine 3 di 3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Wi-Fi Card: passo 8, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
  9. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 9, immagine 2 di 2
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable off of the Wi-Fi card.
    • Be careful as you pry the cables off of the Wi-Fi card as they are fragile and easily damaged.
  10. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 10, immagine 2 di 2
    • Slide the Wi-Fi card out from the slot to remove it from the board.
Conclusione
Altre 2 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
23.384 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.449 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 222
Tutti i Tempi: 5,137
