Introduzione
Use this guide to replace the coin cell battery in your Lenovo ThinkPad T470.
A coin cell battery, also called a CMOS battery, is responsible for remembering specific information such as the computer’s date, time, and BIOS settings when the laptop is turned off.
When the coin cell battery fails, an error message will appear when you power on your laptop.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
