Salta al contenuto principale
Lenovo ThinkPad T460 Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad T460 Keyboard Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T460 Keyboard Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T460 Keyboard Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T460 Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T460 Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Use the pointed end of a spudger to pry the two rubber stoppers out of the battery compartment.
  4. Lenovo ThinkPad T460 Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 4, immagine 2 di 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T460 Keyboard Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T460 Keyboard Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T460 Keyboard Replacement: passo 5, immagine 3 di 3
    • Use the pointed end of a spudger to push the keyboard towards the screen using the two notches on the bottom of the keyboard.
  6. Lenovo ThinkPad T460 Keyboard Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 6, immagine 2 di 2
    • Loosen the six captive screws in the keyboard frame using a Phillips #0 screwdriver.
    • These screws are hard to see. Make sure you have pushed the keyboard towards the screen as far as it will go to see the screws better.
  7. Lenovo ThinkPad T460 Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 7, immagine 2 di 2
    • Use your hands to pull the keyboard up and towards you by a few millimeters to remove it from its tray.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when lifting it.
  8. Lenovo ThinkPad T460 Keyboard Replacement: passo 8, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 8, immagine 2 di 2
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  9. Lenovo ThinkPad T460 Keyboard Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of blunt-nosed tweezers to lift the black flap away from the cable connectors.
  10. Lenovo ThinkPad T460 Keyboard Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 10, immagine 2 di 2
    • Use the flat end of a spudger to flip up the locking flap securing the ribbon cable.
  11. Lenovo ThinkPad T460 Keyboard Replacement: passo 11, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 11, immagine 2 di 2
    • Use a pair of blunt-nosed tweezers to pull the ribbon cable out of its connector.
  12. Lenovo ThinkPad T460 Keyboard Replacement: passo 12, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to flip up the locking flap securing the bottom ribbon cable.
  13. Lenovo ThinkPad T460 Keyboard Replacement: passo 13, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 13, immagine 2 di 2
  14. Lenovo ThinkPad T460 Keyboard Replacement: passo 14, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 14, immagine 2 di 2
    • Pull the ribbon cables through the slot in the black flap.
    • Remove the black flap from the keyboard.
  15. Lenovo ThinkPad T460 Keyboard Replacement: passo 15, immagine 1 di 2 Lenovo ThinkPad T460 Keyboard Replacement: passo 15, immagine 2 di 2
    • Use your hands to lift the keyboard up and away from the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
82.723 Reputazione
202 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.439 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 184
Tutti i Tempi: 5,483
