Salta al contenuto principale
Lenovo ThinkPad S145-15AST Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad S145-15AST Battery Replacement, Remove the back cover: passo 1, immagine 1 di 1
    • Unplug and power off your device.
    • Touch a grounded object like a metal fridge to discharge any static electricity. Do not do the repair on carpeted floors, do the repair preferably on wooden floors.
    • The screws circled in red are 7mm M2.5's. The screws circled in orange are 4mm M2.5's.
    • Remove the screws with your Phillips #0 screwdriver.
    • Wedge an opening card (recommended) or spudger into the ridges of the case and carefully pop off the clips securing the back cover and make sure to not break any clips.
    • Remove the back cover.
  2. Lenovo ThinkPad S145-15AST Battery Replacement, Battery removal: passo 2, immagine 1 di 2 Lenovo ThinkPad S145-15AST Battery Replacement, Battery removal: passo 2, immagine 2 di 2
    • Pull at the connector of the battery, circled in red. It should just pop out. If not then don't force it!
    • Use your Phillips #00 screwdriver to remove the three 6mm M2 screws securing the battery, that are circled in yellow in the image.
    • Now just pull up on the battery and remove it.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
    • Align your new battery with the screw holes.
    • Install the three 6mm M2 screws into the screw slots.
    • Reconnect the battery connector.
    • Reattach the back cover and reinstall the ten M2.5 screws.
    • Now you should be all good to go!
Conclusione
For best performance, calibrate your new battery after completing this guide.
Make sure to take your used battery to a e-waste recycling center.
Oliver Fallon
Membro da: 07/04/23
199 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 68
