Salta al contenuto principale
Joy-Con Battery Replacement
Cosa ti serve
    • In order to open the joy-con, remove the joy-con from the console. Then, Using the Tri-point Y00 Screwdriver, remove the four corner screws. MAKE SURE TO OPEN SLOWLY!!!
    Chiedi a FixBot
    Aggiungi Commento
    • After it is open, use the spudger to remove the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
    • Using the opening pick, insert it on the side of the battery in-between the battery and the battery casing then pry the battery up.
    • IF THE BATTERY IS INFLATED, BE VERY CAREFUL!!! (Use gloves.)
    Chiedi a FixBot
    Aggiungi Commento
    • To fix the battery, you need a battery!
    Chiedi a FixBot
    Aggiungi Commento
    • Place in the new battery in the EXACT same way.
    • If the adhesive is still sticky, you can reuse it. If not, you need to put some more on. Double stick Tessa tape works great for this. Please note you will need to scrape off the old tape or use things like Goo-Be-Gone.
    Chiedi a FixBot
    Aggiungi Commento
  1. Strumento utilizzato in questo passaggio:
    • With the battery connector in hand, (or tweezers!) place it over the connector on the motherboard, and press down. If it does not connect together, flip over and try again.
    Chiedi a FixBot
    Aggiungi Commento
    • To put the case back together, then place the case right above the case and then push it together until you hear a click.
    Chiedi a FixBot
    Aggiungi Commento
    • In order to replace the screws, place the four screws in their respective holes and screw them in using the Tri-point Y00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Now your Joy-con should work now.
Altre 2 persone hanno completato questa guida.
JFix
Membro da: 10/03/23
553 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 49
Ultimi 30 giorni: 209
Tutti i Tempi: 5,543
