Salta al contenuto principale
IINE Retro Pocket Joystick Replacement
Cosa ti serve
  1. IINE Retro Pocket Joystick Replacement, Remove the screws: passo 1, immagine 1 di 3 IINE Retro Pocket Joystick Replacement, Remove the screws: passo 1, immagine 2 di 3 IINE Retro Pocket Joystick Replacement, Remove the screws: passo 1, immagine 3 di 3
    • Set the controller down on your working surface.
    • Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
    • Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
    Chiedi a FixBot
    Aggiungi Commento
  2. IINE Retro Pocket Joystick Replacement, Remove the back plate: passo 2, immagine 1 di 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: passo 2, immagine 2 di 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: passo 2, immagine 3 di 3
    • Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
    • As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
    • Be careful not to damage the retaining clips. they're small and thin, and may break easily.
    • Lift the back plate up and away from you, and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. IINE Retro Pocket Joystick Replacement: passo 3, immagine 1 di 1
    • Once the back plate is removed, you now have access to the internals of the controller.
    Chiedi a FixBot
    Aggiungi Commento
  4. IINE Retro Pocket Joystick Replacement, Disconnect the battery: passo 4, immagine 1 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: passo 4, immagine 2 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: passo 4, immagine 3 di 3
    • For safety and to prevent damage, disconnect the battery before continuing.
    • Locate the battery connector.
    • Use a pair of tweezers to carefully push on the notches of the battery connector and disconnect it from the socket.
    • Do not pull on the wires!
    Chiedi a FixBot
    Aggiungi Commento
  5. IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: passo 5, immagine 1 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: passo 5, immagine 2 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: passo 5, immagine 3 di 3
    • Locate the ZIF connector of the right joystick.
    • Use a pair of tweezers to flip up the black flap of the ZIF connector and unlock it.
    • Disconnect the joystick cable by carefully pulling it straight out of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  6. IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: passo 6, immagine 1 di 2 IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the right joystick.
    Chiedi a FixBot
    Aggiungi Commento
  7. IINE Retro Pocket Joystick Replacement, Remove the right joystick: passo 7, immagine 1 di 2 IINE Retro Pocket Joystick Replacement, Remove the right joystick: passo 7, immagine 2 di 2
    • Lift up the joystick module and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  8. IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: passo 8, immagine 1 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: passo 8, immagine 2 di 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: passo 8, immagine 3 di 3
    • Locate the ZIF connector of the left joystick.
    Chiedi a FixBot
    Aggiungi Commento
  9. IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: passo 9, immagine 1 di 2 IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: passo 9, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the left joystick.
    Chiedi a FixBot
    Aggiungi Commento
  10. IINE Retro Pocket Joystick Replacement, Remove the left joystick: passo 10, immagine 1 di 2 IINE Retro Pocket Joystick Replacement, Remove the left joystick: passo 10, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Once the controller is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick.
Altre 2 persone hanno completato questa guida.
Aardimus
Membro da: 04/30/26
315 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 10
Ultimi 30 giorni: 70
Tutti i Tempi: 284
