Salta al contenuto principale
Fujitsu Lifebook E5511
Cosa ti serve
  1. Fujitsu Lifebook E5511, Battery removal: passo 1, immagine 1 di 1
    • Remove the battery by sliding (1) up and (2) to the right, then just lift it out.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fujitsu Lifebook E5511, RAM/SSD/LTE-modem: passo 2, immagine 1 di 2 Fujitsu Lifebook E5511, RAM/SSD/LTE-modem: passo 2, immagine 2 di 2
    • Remove three screws holding the maintence panel. Remove the panel by lifting it from the right side. Now we can access RAM, SSD and a possible LTE-modem.
    • Remove all marked screws to remove the bottom cover. Screws marked with different colors have different thread/length. Blue screw holds the SSD against the bottom cover, so that and the drive has to come out. RAM can be removed, but it's not mandatory.
    • LTE-modem would be located under the left side green arrow. You can see the antennas there.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fujitsu Lifebook E5511, Insides: passo 3, immagine 1 di 3 Fujitsu Lifebook E5511, Insides: passo 3, immagine 2 di 3 Fujitsu Lifebook E5511, Insides: passo 3, immagine 3 di 3
    • To completely remove the bottom cover, use a opening pick or something similar to pry the cover open from a corner. It starts to open very easily and can be just lifted up once all the clips are opened.
    • Use air duster to remove dust from the insides, also from the "fan grille" on bottom cover
    Chiedi a FixBot
    Aggiungi Commento
  4. Fujitsu Lifebook E5511, Wifi module: passo 4, immagine 1 di 1
    • Wifi module has one screw and two antennas to it. Unplug the antennas, remove the screw and lift the module out.
    • Below the Wifi module are LTE antennas and a slot for optional LTE modem
    Chiedi a FixBot
    Aggiungi Commento
  5. Fujitsu Lifebook E5511, CMOS battery: passo 5, immagine 1 di 1
    • CMOS battery can be removed with an opening pick or something similar. Just lift it gently from the right side.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fujitsu Lifebook E5511, Thermal paste and cooler cleanup: passo 6, immagine 1 di 3 Fujitsu Lifebook E5511, Thermal paste and cooler cleanup: passo 6, immagine 2 di 3 Fujitsu Lifebook E5511, Thermal paste and cooler cleanup: passo 6, immagine 3 di 3
    • CPU-cooler has 4 screws, fan has 2 screws and power cable
    • Clean out old thermal paste with paper towel and IPA/paste cleaner. Clean out dust from the fan and heatsink with canned air.
    • Place a small blob of thermal paste to the center of CPU, mount the cooler and use x-pattern to screw it in. If you feel like it, remove the cooler again to check if amount of paste is good.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Mikael
Membro da: 03/24/26
31 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 23
Tutti i Tempi: 60
