Salta al contenuto principale
Fan & Interior Cleaning
Cosa ti serve
  1. Fan & Interior Cleaning, Lower Case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fan & Interior Cleaning: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fan & Interior Cleaning: passo 3, immagine 1 di 2 Fan & Interior Cleaning: passo 3, immagine 2 di 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fan & Interior Cleaning, Battery Connector: passo 4, immagine 1 di 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fan & Interior Cleaning: passo 5, immagine 1 di 2 Fan & Interior Cleaning: passo 5, immagine 2 di 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fan & Interior Cleaning: passo 6, immagine 1 di 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fan & Interior Cleaning, Remove fan bumper: passo 7, immagine 1 di 3 Fan & Interior Cleaning, Remove fan bumper: passo 7, immagine 2 di 3 Fan & Interior Cleaning, Remove fan bumper: passo 7, immagine 3 di 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The bumper is gently held in place by the lips in the third image which wrap under the heat sink. There is no adhesive, so removal and reseating should be easy.
    Chiedi a FixBot
    Aggiungi Commento
  8. Fan & Interior Cleaning, iSight Cable: passo 8, immagine 1 di 2 Fan & Interior Cleaning, iSight Cable: passo 8, immagine 2 di 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    • The cable connector is small and delicate, so make sure to nudge it out a little bit at a time from each side, alternating until it is fully out. A spudger or tweezers are ideal for this.
    Chiedi a FixBot
    Aggiungi Commento
  9. Fan & Interior Cleaning: passo 9, immagine 1 di 2 Fan & Interior Cleaning: passo 9, immagine 2 di 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
    • You can optionally use hot air to soften the adhesive and/or a spudger to help separate the cable from the fan housing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Fan & Interior Cleaning, Disconnect I/O board cable: passo 10, immagine 1 di 2 Fan & Interior Cleaning, Disconnect I/O board cable: passo 10, immagine 2 di 2
    • One of the screws holding the top shell of the fan assembly is hidden just behind the I/O board cable.
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  11. Fan & Interior Cleaning: passo 11, immagine 1 di 2 Fan & Interior Cleaning: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
    Chiedi a FixBot
    Aggiungi Commento
  12. Fan & Interior Cleaning: passo 12, immagine 1 di 2 Fan & Interior Cleaning: passo 12, immagine 2 di 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable. It will only be in the way momentarily, so don't try forcing it to stay.
    Chiedi a FixBot
    Aggiungi Commento
  13. Fan & Interior Cleaning: passo 13, immagine 1 di 1
    • Remove the following screws securing the fan assembly cover to the rest of the assembly:
    • One 5.0 mm T5 Torx screw.
    • This screw holds the upper case, main fan assembly, and fan assembly together, and so must be removed.
    • 3 Phillips #000 screws.
    • The bottom right screw is just under the I/O board cable, and will be visible after it has been lifted out of the way.
    Chiedi a FixBot
    Aggiungi Commento
  14. Fan & Interior Cleaning, Remove dust: passo 14, immagine 1 di 1
    • The inside of the case plate will likely have dust caked on. Since this piece has no delicate electronics, you can simply wipe it with your Anti-static brush, or even better, a used toothbrush.
    • Ideally, do this step outside.
    • You can optionally use a small amount of rubbing alcohol if gunk has built up anywhere (as long as you let it dry before reinstalling), though this shouldn't usually be necessary.
    Chiedi a FixBot
    Aggiungi Commento
  15. Fan & Interior Cleaning: passo 15, immagine 1 di 1
    • Use your compressed air can to blow away loose dust from the motherboard.
    • Follow the instructions on your compressed air can. Generally, you will hold the nozzle 3-4 inches from the target, right side up, and only apply short bursts of air.
    • Do not blow compressed air near the fan assembly without holding the fan still, as this can spin the fan blades at high speed and generate a damaging voltage.
    • If you are wearing a grounded anti-static bracelet, you can remove larger chunks of dust by hand.
    • If you have an anti-static brush, you can use it to dust away or loosen dust before blasting it away with the air.
    Chiedi a FixBot
    Aggiungi Commento
  16. Fan & Interior Cleaning: passo 16, immagine 1 di 1
    • If there is only a light amount of dust in the heat sink and fan assembly, you can blow it out without removing the fan assembly cover, as long as you hold the fan steady.
    • If the fan blades are very dusty, you will need to remove the fan assembly cover to clean them more thoroughly and remove any large clumps of dust.
    Chiedi a FixBot
    Aggiungi Commento
    • Remove the fan assembly cover; it should come off with no resistance at all if you removed all 4 screws
    • Use a brush to loosen caked on dust.
    • As long as you are careful to only brush the plastic fan blades and enclosure, you don't strictly need an anti-static brush. An old toothbrush will once again work perfectly here.
    Chiedi a FixBot
    Aggiungi Commento
  17. Fan & Interior Cleaning: passo 18, immagine 1 di 1
    • Carefully turn the laptop upside down on a flat surface to let the loose dust fall out.
    • At this point, the only thing besides dust that might fall out (besides dust) are the rubber hinge covers, whose adhesive might be loose. Simply replace these as shown in the last photo if necessary.
    Chiedi a FixBot
    Aggiungi Commento
    • You should have a less obstructed view of the heat sink fins. Loosen any caked dust with an anti-static brush before blasting loose dust out the back vents of the case with compressed air.
    • Again, hold the fan still whenever blowing compressed air anywhere near it.
    • Blow away any loose air from the interior of the fan assembly.
    • Inspect the rest of the interior of the computer for stray dust that may have landed, and clear that away before closing everything back up.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 66
Ultimi 30 giorni: 249
Tutti i Tempi: 7,245
