Salta al contenuto principale
Dell Precision 5530 Battery Replacement
Cosa ti serve
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect all network cables from the computer (if available).
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Press and hold the power button for few seconds, to ground the system board.
    Chiedi a FixBot
    Aggiungi Commento
  1. Dell Precision 5530 Battery Replacement, Remove the base cover screws: passo 2, immagine 1 di 1
    • Close the display and turn the computer over.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Pry the edges of the base cover and lift it to remove it from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Precision 5530 Battery Replacement, Remove the base cover: passo 3, immagine 1 di 1
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Precision 5530 Battery Replacement, Remove the battery: passo 4, immagine 1 di 1
    • Disconnect the battery cable from the system board.
    • Remove the M2x4 screws that secure the battery to the computer.
    • Lift the battery off the computer.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Altre 8 persone hanno completato questa guida.
Max Kletskov
Membro da: 04/22/20
41.810 Reputazione
16 guide realizzate
1Commento della guida
This is not a Precision 5530 2 in 1. Instructions are very similar, but the battery connector is in the middle of the unit and there are two screws that go over top of battery connector connecting a heat sink. Secondly, there are no screws in the middle of the cover, only around the perimeter.
Also, worth noting that the cover is very difficult to remove the first time.
richard lavanture - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 27
Ultimi 30 giorni: 131
Tutti i Tempi: 8,500
