Salta al contenuto principale
Dell Inspiron 15-7569 Battery Replacement
Cosa ti serve
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, immagine 1 di 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, immagine 2 di 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team S5-G4, Walkup Fall 2017 Membro di USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Membri
6 guide realizzate
2Commenti sulla guida
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Rispondi Condividi
Helpful and easy. As noted in a past comment, only 2 screws are in the battery. Nothing to it.
Thanks,
Robert
Robert B - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 67
Tutti i Tempi: 7,376
