Salta al contenuto principale
iVIEW-754TPC Camera Assembly Replacement
Cosa ti serve
    1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, immagine 1 di 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, immagine 2 di 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, immagine 3 di 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Chiedi a FixBot
      Aggiungi Commento
    1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, immagine 1 di 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, immagine 2 di 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      Chiedi a FixBot
      Aggiungi Commento
    2. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: passo 3, immagine 1 di 2 iVIEW-754TPC Camera Assembly Replacement, Remove Camera: passo 3, immagine 2 di 2
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Robert Clark
Membro da: 01/21/15
1.065 Reputazione
7 guide realizzate
USF Tampa, Team 5-4, Brown Winter 2015 Membro di USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 505
