Salta al contenuto principale
iVIEW-754TPC Battery Replacement
Cosa ti serve
    1. iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, immagine 1 di 3 iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, immagine 2 di 3 iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, immagine 3 di 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Chiedi a FixBot
      Aggiungi Commento
    1. iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, immagine 1 di 3 iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, immagine 2 di 3 iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, immagine 3 di 3
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    1. iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, immagine 1 di 3 iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, immagine 2 di 3 iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, immagine 3 di 3
      • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
      • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
      • To ease reassembly, take note of which wire goes to the negative and positive terminals.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
calvin
Membro da: 01/21/15
188 Reputazione
Una guida realizzata
USF Tampa, Team 5-4, Brown Winter 2015 Membro di USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 2,795
