Salta al contenuto principale
iRobot Braava 320 Battery Replacement
Cosa ti serve
    1. iRobot Braava 320 Battery  Replacement, Battery: passo 1, immagine 1 di 1
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      Chiedi a FixBot
      Aggiungi Commento
    2. iRobot Braava 320 Battery  Replacement: passo 2, immagine 1 di 1
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. iRobot Braava 320 Battery  Replacement: passo 3, immagine 1 di 2 iRobot Braava 320 Battery  Replacement: passo 3, immagine 2 di 2
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S1-G3, Nance Spring 2017 Membro di USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membri
15 guide realizzate
1Commento della guida
where do I get a new battery from?
j.svetlova - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 31
Tutti i Tempi: 5,155
