Salta al contenuto principale
iPod Nano 4th Generation Display Replacement
Cosa ti serve
    1. iPod Nano 4th Generation Display Replacement, Glass Panel: passo 1, immagine 1 di 2 iPod Nano 4th Generation Display Replacement, Glass Panel: passo 1, immagine 2 di 2
      • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
      • Pry the top bezel off the adhesive securing it to the display retainer.
      • At this point the hold switch slider is free and may fall. Be careful not to lose it.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Display Replacement: passo 2, immagine 1 di 1
      • Remove the hold switch slider from the top of the Nano.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Display Replacement: passo 3, immagine 1 di 1
      • Remove the two angled Phillips screws from the two corners of the display retainer.
      • These screw heads are extremely small and easily stripped.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Display Replacement: passo 4, immagine 1 di 1
      • Insert an iPod opening tool between the outer case and the display retainer.
      • Use the tool to slide the display assembly out of the case slightly.
      • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
      • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Display Replacement: passo 5, immagine 1 di 1
      • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
      • Do not put unnecessary tension on the very thin display data cable.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Nano 4th Generation Display Replacement: passo 6, immagine 1 di 2 iPod Nano 4th Generation Display Replacement: passo 6, immagine 2 di 2
      • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
      • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Nano 4th Generation Display Replacement: passo 7, immagine 1 di 1
      • Lift the glass panel out of the Nano.
      • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 4th Generation Display Replacement, Display: passo 8, immagine 1 di 1
      • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
      • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Display Replacement: passo 9, immagine 1 di 1
      • Peel back the Kapton tape covering the display data cable socket.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Display Replacement: passo 10, immagine 1 di 1
      • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Display Replacement: passo 11, immagine 1 di 1
      • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
      • Be careful not to rip the display data cable.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Display Replacement: passo 12, immagine 1 di 1
      • Pull the display out of the Nano, minding the hold switch cable that may get caught.
      • As you pull the display out of the case, be careful not to break the hold switch cable.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 4th Generation Display Replacement, Display: passo 13, immagine 1 di 1
      • If present, remove the strip of tape covering the display electronics.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Display Replacement: passo 14, immagine 1 di 2 iPod Nano 4th Generation Display Replacement: passo 14, immagine 2 di 2
      • The display bracket is attached to the display by a strip of adhesive around its perimeter.
      • Use the edge of an iPod opening tool to carefully pry the display bracket off the rear of the display.
      • Continue separating the display bracket along the side of the display.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Display Replacement: passo 15, immagine 1 di 1
      • Separate the display bracket from the other side of the display.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Display Replacement: passo 16, immagine 1 di 1
      • Use an iPod opening tool to carefully peel the display electronics off the display bracket.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Display Replacement: passo 17, immagine 1 di 1
      • Remove the display from the display bracket.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 49 persone hanno completato questa guida.
5Commenti sulla guida
And what to do if you break the hold switch?!
Fred Rodolf - Rispondi Condividi
I believe you might have to buy a new one online.
Ad123re - Rispondi Condividi
Hello, can I connect a 10" LCD display to the iPod display connection instead of it's original display?
irrevocablemihiranga97 - Rispondi Condividi
No. No idea what you're talking about because even if it was connected it wouldn't physically fit. TV out would be your best friend.
the bongo guy - Rispondi Condividi
Your instructions are well prepared and very helpful! Thanks a lot!
ndinijimi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 83
Ultimi 30 giorni: 275
Tutti i Tempi: 84,895
