Salta al contenuto principale
iPod Nano 4th Generation Click Wheel Replacement
Cosa ti serve
    1. iPod Nano 4th Generation Click Wheel Replacement, Glass Panel: passo 1, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement, Glass Panel: passo 1, immagine 2 di 2
      • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
      • Pry the top bezel off the adhesive securing it to the display retainer.
      • At this point the hold switch slider is free and may fall. Be careful not to lose it.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Click Wheel Replacement: passo 2, immagine 1 di 1
      • Remove the hold switch slider from the top of the Nano.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Click Wheel Replacement: passo 3, immagine 1 di 1
      • Remove the two angled Phillips screws from the two corners of the display retainer.
      • These screw heads are extremely small and easily stripped.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Click Wheel Replacement: passo 4, immagine 1 di 1
      • Insert an iPod opening tool between the outer case and the display retainer.
      • Use the tool to slide the display assembly out of the case slightly.
      • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
      • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Click Wheel Replacement: passo 5, immagine 1 di 1
      • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
      • Do not put unnecessary tension on the very thin display data cable.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Nano 4th Generation Click Wheel Replacement: passo 6, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement: passo 6, immagine 2 di 2
      • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
      • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Nano 4th Generation Click Wheel Replacement: passo 7, immagine 1 di 1
      • Lift the glass panel out of the Nano.
      • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 4th Generation Click Wheel Replacement, Display: passo 8, immagine 1 di 1
      • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
      • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Click Wheel Replacement: passo 9, immagine 1 di 1
      • Peel back the Kapton tape covering the display data cable socket.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Click Wheel Replacement: passo 10, immagine 1 di 1
      • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Click Wheel Replacement: passo 11, immagine 1 di 1
      • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
      • Be careful not to rip the display data cable.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Click Wheel Replacement: passo 12, immagine 1 di 1
      • Pull the display out of the Nano, minding the hold switch cable that may get caught.
      • As you pull the display out of the case, be careful not to break the hold switch cable.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 4th Generation Click Wheel Replacement, Logic Board Assembly: passo 13, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement, Logic Board Assembly: passo 13, immagine 2 di 2
      • Insert an iPod opening tool between the bottom bezel and the dock connector.
      • Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 4th Generation Click Wheel Replacement: passo 14, immagine 1 di 1
      • Remove the three Phillips screws along the bottom of the Nano.
      • The slightly longer of the three screws belongs in the middle.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 4th Generation Click Wheel Replacement: passo 15, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement: passo 15, immagine 2 di 2
      • Use an iPod opening tool to pry the aluminum dock bezel out of the Nano.
      • The dock bezel is very thin cast aluminum. To avoid breaking it, do not excessively flex it during removal.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 4th Generation Click Wheel Replacement: passo 16, immagine 1 di 3 iPod Nano 4th Generation Click Wheel Replacement: passo 16, immagine 2 di 3 iPod Nano 4th Generation Click Wheel Replacement: passo 16, immagine 3 di 3
      • Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
      • The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
      • Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 4th Generation Click Wheel Replacement: passo 17, immagine 1 di 1
      • Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Nano 4th Generation Click Wheel Replacement: passo 18, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement: passo 18, immagine 2 di 2
      • Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Nano 4th Generation Click Wheel Replacement: passo 19, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
      • Before proceeding, be sure that both the click wheel ribbon cable socket and its cable are freed from the adhesive securing them to the dock connector and logic board.
      • Peel back the cable on both ends!
      Chiedi a FixBot
      Aggiungi Commento
    8. iPod Nano 4th Generation Click Wheel Replacement: passo 20, immagine 1 di 1
      • Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
      • When reassembling, ensure the click wheel cable is toward the front of the Nano and not in the grooves on the side. If it is in the groove you will probably cut it while sliding the logic board into place.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 4th Generation Click Wheel Replacement, Click Wheel: passo 21, immagine 1 di 2 iPod Nano 4th Generation Click Wheel Replacement, Click Wheel: passo 21, immagine 2 di 2
      • Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
      • This requires a good amount of force. Work slowly.
      • It may be helpful to use an edged tool to separate the adhesive from the click wheel on the inside of the Nano while pressing it down from the outside.
      • Remove the click wheel from the inside of the Nano.
      • Be careful not to let the click-wheel slide on the metal plate supporting it, as it will break the flat cable. Apply force perpendicular to the click-wheel.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 54 persone hanno completato questa guida.
3Commenti sulla guida
Hello, does anybody know where to fin a clickwheel replacement for the nano 4th gen ? I can't seem to find it on the internet, the only sellers who did have it in stock was on alibaba, and he said to me there were not any left when I contacted him.
Emmanuel Neff - Rispondi Condividi
Sure! My favorite site is EOE or elite obsolete electronics. They have a lot of click wheels. Additionally, you can find a lot on eBay for a few dollars.
Ad123re - Rispondi Condividi
This is the best set of instructions I’ve read regarding anything in the past 9 or 10 years. They are clearly stated, grammar is perfect and perfectly proofread before being published. It’s fits with the quality of simple writing I grew up with in the 50’s and 60’s and haven’t seen or read in the past many, many years. Nothing I’ve had to use over recent years (generally from China) comes close. This level of quality alone gives me confidence in the company itself.
Gary Blunk - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 53
Ultimi 30 giorni: 316
Tutti i Tempi: 149,663
