Salta al contenuto principale
iPod Nano 1st Generation Display Replacement
Cosa ti serve
    1. iPod Nano 1st Generation Display Replacement, Rear Panel: passo 1, immagine 1 di 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 1st Generation Display Replacement: passo 2, immagine 1 di 1
      • The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
      • To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 1st Generation Display Replacement: passo 3, immagine 1 di 2 iPod Nano 1st Generation Display Replacement: passo 3, immagine 2 di 2
      • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
      • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 1st Generation Display Replacement: passo 4, immagine 1 di 1
      • Insert a small iPod opening tool into the seam on the Hold button side of the iPod, with the edge of the tool pointing toward the rear panel.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 1st Generation Display Replacement: passo 5, immagine 1 di 1
      • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
      • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Nano 1st Generation Display Replacement: passo 6, immagine 1 di 3 iPod Nano 1st Generation Display Replacement: passo 6, immagine 2 di 3 iPod Nano 1st Generation Display Replacement: passo 6, immagine 3 di 3
      • Repeat the same procedure listed in the previous step to free the five clips along the headphone jack side of the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Nano 1st Generation Display Replacement: passo 7, immagine 1 di 1
      • After ensuring all tabs are free, separate the two halves of the iPod.
      • The rear panel is now free from the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 1st Generation Display Replacement, Battery & Logic Board: passo 8, immagine 1 di 1
      • Remove any kapton tape over the screws, if necessary.
      • Remove the following 3 screws:
      • Two 3 mm Phillips screws near the dock connector.
      • One 4 mm Phillips screw along the edge of the logic board.
      • During reassembly, make sure to put back any tape or plastic you remove. This will prevent any shorts between the logic board and the rear panel. If your tape is unusable, kapton tape can be purchased online.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 1st Generation Display Replacement: passo 9, immagine 1 di 1
      • Peel up the ground strap connecting the battery to the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 1st Generation Display Replacement: passo 10, immagine 1 di 2 iPod Nano 1st Generation Display Replacement: passo 10, immagine 2 di 2
      • Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
      • Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 1st Generation Display Replacement: passo 11, immagine 1 di 1
      • Gently lift up on the dock connector end of the logic board to ensure the logic board is free.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Nano 1st Generation Display Replacement: passo 12, immagine 1 di 1
      • Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
      • Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
      • Slide the logic board out of its holding brackets on the rear of the display.
      • The logic board is still connected to the iPod by two ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Nano 1st Generation Display Replacement: passo 13, immagine 1 di 1
      • Disconnecting the following two ribbon cables may be challenging. To prevent straining the cables or connectors, you can only separate the two halves of the iPod about 1/2 inch during the process.
      • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Nano 1st Generation Display Replacement: passo 14, immagine 1 di 1
      • Use a spudger to slide the display ribbon out of its connector.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPod Nano 1st Generation Display Replacement: passo 15, immagine 1 di 1
      • Use a spudger to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPod Nano 1st Generation Display Replacement: passo 16, immagine 1 di 1
      • Use a spudger to slide the click wheel ribbon out of its connector.
      Chiedi a FixBot
      Aggiungi Commento
    10. iPod Nano 1st Generation Display Replacement: passo 17, immagine 1 di 1
      • The logic board and battery are now free from the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Nano 1st Generation Display Replacement, Display: passo 18, immagine 1 di 1
      • Use a spudger to carefully pry up the adhesive holding down the edge of the display.
      • Be careful not to slide the spudger in too far to prevent scratching the display.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Nano 1st Generation Display Replacement: passo 19, immagine 1 di 1
      • Gently lift up on one corner of the display to separate the adhesive holding the display in place.
      • Lift up on the other corner of the display in the same manner.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Nano 1st Generation Display Replacement: passo 20, immagine 1 di 1
      • Lift the display up and out of the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Nano 1st Generation Display Replacement: passo 21, immagine 1 di 1
      • The display is now free from the iPod.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 51 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
2Commenti sulla guida
spegazione molto detagliata un complimento alla persona grazie
gianni - Rispondi Condividi
Noice! I accidentally stepped on my screen (TBF, my cat was in the way) so I decided to consult the almighty iFixit! I did have a bit of trouble removing the screen, though, as I found the adhesive too strong to pull. Therefore, I used my spudger as a lever to pull it out.
As this was my first intro into the world of DIY electronics repairing (that is to say, one that didn't have me losing every piece to it), I'm ready to see what else can come at me!
(Also, be careful not to put any fingerprints on the inside of the screen. I nearly did that, but some toilet paper and some isopropyl fixed it up.)
GrayDolf - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 32
Ultimi 30 giorni: 158
Tutti i Tempi: 43,489
